Skydiver Scott
- Joined
- Aug 3, 2009
- 25
I am looking for a replacement lower on my 1987 85HP Force model 856X7A. I am thinking it is a 20" but am curious what I specifically need to measure to be sure. Measure the drive shaft from the top of the Water Pump to the top of the splines? Also it seems that there is a good deal of interchangeability with these lower units. Any specific tips to look for? I am searching e-bay and have a few potential options and I was thinking if it was a single shaft (not split) pre 90's model and had an exhaust snout as I am pretty sure this motor is not a through Prop exhaust and is from a least a 85 or a 120 HP it should work.... Am I wrong on that? I know the gearing might be slightly different with the 120HP lower on the 85HP but a prop change can adjust for that iof I am thinking correctly.
Thanks for the input.
Scott
Scott
