85HP WOT Cutout and Die
brucemerson
I've replaced the diaphragm (which didn't look damaged) and it did no good. Can I substitute an electric fuel pump? Can the generator provide enough power to keep from draining the battery?
jerryjerry05
Re: 85HP WOT Cutout and Die
The motors stator should generate enough power to keep the battery up.
If it goes dead while your out then the regulator is suspect.
NO on the electric pump.
Is the ball staying up or going flat.Check the vent lines for obstructions.
The squeezie can be bad and blocking the flow.J
