yftcaptdan
Thread starter- Joined
- Oct 27, 2010
- 8
I've got an 85hp yamaha and have just redone a lot of the electrical(new relays and new pulser coil). I'm getting a shudder like a spun hub on the prop when I try to give it gas to try and plane off. It will move forward at a low rpm ok. I just put a new prop so i know its not the hub. Sometimes it will plane off fine and run great. When it does do the shudder it also will not rev in neutral. It goes into a safe mode of sorts and will rev a little then kind of sputtter like its dropped a cylinder. Will a bad neutral safety switch do this or is it a pad plug or is it a bad cylinder? I checked compression and the top cylinder is a little off from the others. Thanks for any input.
