86 140hp evinrude runs rough.
8up
Here's the deal. I have this 1986 140hp evinrude that has 40 hours on a 1999 rebuild, It had been sitting for the last 2 years or so before I bought it. <br /> The motor has a rough idle and while accelerating and full throttle the thing acts like it is dropping out a cyl off and on intermitantly. Compression check shows 130 psi on 3 out of 4 cyl. 115 psi on the last.When we squirted oil in the low cyl. the pressure came to 130. <br /> With that being said...I have replaced the plugs, wires and installed a fuel/water seporator and new fuel lines on the boat. While out last time I pulled plug wires one at a time to see if the motor ran differently. The one cyl that had low compression did not effect the way it ran as much as the others. I cleaned up the coils and swapped them around and I can still lift the one wire without affecting the motor alot.<br /> Now that I have rambled on...What do you think.<br /><br /> thanks 8up
93bronco
Ensign
Re: 86 140hp evinrude runs rough.
rebuild the carbs, check the head gasket on low cylinder and also check the recirculation system.
Solittle
Replace water pump & oil in gearcase (new seals on fill & drain plugs).
