Hello, I store a bass boat every year for a friend, and do some work for him when needed. He has this 150 hp ser # A905691. He says that it starts good, idles good, but boggs on take off, and won't get on plane at all. He's had it to the merc shop near his home twice last summer, and still no help. He didn't keep any paperwork, so not sure what all has been done. I can see heads have been resealed. I'm going to replace the fuel hoses (rock hard) but in the meantime, I started to check the ignition. It looks like the stater and or the trigger is newer, so I thought I would check the trigger timing. Marked all 6 cyl's at TDC. I'm assuming that the #1 cyl is the left lower cyl as your looking at the plugs. That is the cyl that is at 0 on the timing mark on compression. All the cylinders check good with the timing light, except #1 (lower left cyl) it is actually fireing on the second stroke. The 0 timing mark is over by the starter when it triggers. Would it be possible that the trigger is bad? Does seem to have good spark on all cylinders (with timing light cranking-havn't ran motor yet.) This motor was always a great performer for him. I've always been amazed at how quick it came out of the hole and on plane. He's always had a merc marina do his work, and winterize. Any thoughts?
Thanks!
Jeff
Thanks!
Jeff
