57chevyeddie
- Joined
- May 7, 2011
- 37
While at the lake a couple weeks ago, my XR2 would'nt run right. I idled out of the "no wake zone" and gave it the gas but it would'nt go. Long story short, back to launch with the trolling motor as my oil injector alarm started sounding. Back on the trailer we only had spark on three cylinders. We suspected switch box. I noticed while examining the problem, the red wire from "advance module" was burned looking where it connects to the switch box. As I pulled on it, the insulation broke at the terminal. I checked closer and the wire seemed almost broken at that point. I added a short piece or wire after cutting about 3 inches off, looking for a solid point in the original wire. After reconnecting the the engine still had issues so I took it home. When I checked for spark I ony had three on one side. The other side was dead. I took it home and orded a switch box. To double check I reversed the inner and outter switch box. Now I have spark on all six again. It seems to be oiling the fuel, no alarm, plenty of smoke. Now the idle is rough, and it pops out the exhaust. Sounds like a back fire. I dissconnected the advance module and the popping stopped. It sounds better but it idles a little rough. Do I need to replace the Advance Module? I'm ready to get back to the lake. Thanks in advance for your advice. Eddie
