Hi everyone. So I'm going to start with some background info here. So I got the motor with the flywheel installed with the magnets off becuase they fell off. I planned to epoxy them back on but dropped one and broke one. So I bought a new one and installed it. And it was somewhat successful in that I got spark on both cylinders. I went to test the motor and found that it would only sputter snd run rough for no more than 5 seconds. I tried to get it started many times taking breaks not to overheat the starter but each time normally it would only sputter for a couple seconds. And then towards when I began to give up I found that it wouldnt even pop, at all. So I put it away. I thought it was a carb issue. I adjusted the idle screw and tried again today. Well still no popping or sputtering what sk ever. So I out the spark tester on and found that neither cylinder has spark now! I know I'm going to need to remove the fkywheel to diagnose, but I just dont get why it would lose spark like that? I put a little epoxy around the edges of the magnets so I would be stunned if they came off. If anyone has any ideas or input it would be greatly appreciated. Thank you
