86 4.3L OMC Stringerdrive
Thread starter- Joined
- May 27, 2023
- 7
I bought an '86 4.3L 4-Barrel with OMC Stringerdrive. Has new 170° thermostat, impeller was replaced 12 hours ago I am told...just installed new Marine water pump on block...starts fine...sounds fine...not dripping water like a freeze plug issue...fire it up...runs straight towards 194° ( 9C on gauge) within 4 minutes...so I shut it down...always garaged...only 488 hours on boat...maybe pull impeller to see if it crapped out?? I need advice...should I let it tap that 200° line...does it need to run up, before thermostat opens using Muffs???...if I pull lower unit to check/replace impeller...is there a good video online for impeller replacement on Stringerdrives?? Thanks in advance!!!
