'86 - '88 merc 135 V-6 serial # HELP!!!
bassboatbuster
I bought This Broken Bass boat - it's a 1986 Winner. The serial # plate is gone, and I have no idea on how to find it. Does anyone know if there is any identifying marks/parts I should look for to have an idea of the exact serial #? The reason I need to know is that I think the stator is bad (resistor testing showed about half what the manual said) but I need to find out the serial # to confirm resitor settings in manual, and to make sure the proper stator is on the motor (I don't want to replace the wrong stator with the wrong stator). <br /><br />also, I found a small solid state electric box, about 2"X3"X3/4" on the top of the engine, mounted near the back on the port side with 2 screws , and it has 3 wires - black, white w/black stripe, and a red wire. the black wire is grounded to the motor, and the white w/blackstripe and the red are twisted together and taped with electrical tape (does not look like factory specs) Anyone know what the box is? <br /><br />Any help is greatly appreciated.<br />Thanks
dicktaber
Re: '86 - '88 merc 135 V-6 serial # HELP!!!
The box you speak of is the idle stabiliser--it advances timing to maintain idle speed. I'm told the motor will run without it and that seems to be the case.<br />Sorry I can't help with the stator question; I'm trying to figure out my own stator issues as well. What are your symptoms?
AndrewB
There should be a serial no. stamped on the top of one of the heads. Cant exactly remember which one, the left i thing but its easy to find. Just take the cowel off and its stamped on a flat circular (bout an inch in diameter)part of the head.
