86-88--mercury gas oil ratio mix---200hp
basspro68
ok might be asking a stupid question here --whats the gas to ratio mix ive been using 50 to 1----seems like its doing a lot of smoking.maybe to rich mixture or not enough dont really know.been using 16ounces per 6 gals.gas
JB
Re: 86-88--mercury gas oil ratio mix---200hp
50:1 is correct, BP. If you don't like the smoke try going to a synthetic oil.
basspro68
thanks for the info alot of help.
gss036
If you are using pre mix, that might help explain your tach problems on your other posts, since the oil injection system has been disconnected or removed I would only assume somebody has changed around a bunch of wires..
basspro68
found out it has a 14 pin connector and yes it might have something to do with it.thanks----its just that premix iam sure of it when its done ---hate the one that does itself because the gear gets stripped out and theres goes an high price repair that could have been avoided---but theres pros and cons on everything.thanks
