Re: 86 alpha sterndrive to a bravo 1 sterndrive?
Howdy,
What exactly are you you getting?
If all you're getting is a drive, you'll also need a gimbal assembly and trim cyls for a bravo....Your trim pump and steering hydraulics should switch over ok.
you should also get yourself a OEM service manual. What engine is this going to bolt to? You'll also probably need a bravo y-pipe, and bell housing, and if your engine does not have a raw water pump on it you'll need one of those too complete with mounting bracket etc. If it's 454 you may need the water pump with the fuel pump mounting on it or an electric fuel pump. You didn't say if it's fuel injected....probably not if it's the original engine.... I don't know what year the change came but you might have to drill 2 additional holes in the transom for the Bravo gimbal.
You're doing basically the same thing I did in going from the Cobra to the Bravo.....except I presume you want to keep your engine.
