86 Evinrude 150 hp problem, need some help!
randyray41
When I first start the boat, it starts right up, idles smooth, goes into gear great, takes off perfect, but after running it for a mile or so, it will kill when I decelerate to a stop. After that it wont start with out some throttle and then once it's running it will often kill when I go to put it in gear and when I do get it running, it boggs way down when I try to give it some power. Eventually if you really, really ease it in, the RPM's will gradually go up, almost like it was flooded out.
I pulled all of the plugs and all 3 plugs on the left were wet and black and all 3 on the right were dry and clean.
Bought 6 new plugs, ran boat and same thing happens. One thing I have noticed is when it starts to act up, there is a unusual amount of blue white smoke, almost like the vro pump is pumping to much oil. When its shut off for about 20 mins and I restart it a lot of smoke comes out. Not sure how the vro functions, just grasping at straws with that.
Big flop
Re: 86 Evinrude 150 hp problem, need some help!
When it starts running bad check spark.
Have you checked compression?
