dewdiggler
- Joined
- Apr 20, 2009
- 22
still in need of suggestions here; motor is still starving for gas.
the problem seems to be at the fuel pump
my fuel pump will start pushing gas thru it and then after about 4 to 5 seconds it stops? is that a bad pump?
(took it apart and everything looks fine)
i checked all hoses and no leaks that i could find and seem to be air tight at all the connections.
do i need to actually have the motor running to get a true idea if the pump is working or will just turning it over do the trick.
does the carb have any bearing on helping pull gas thru (just grasping straws)
am i missing something?
all ideas very much appreciated; thanks, Dew
