Fireman Fox
Thread starter- Joined
- Jul 11, 2012
- 5
First, I have to say thank you to everyone on this forum. I have used it for years, and found it very helpful. I finally decided to sign up because, well, I'm on a bit of an adventure with this motor. Got it out for the first time this year and it had a sticky throttle. Disconnected the cables pulled the linkage, finally pulled the flywheel and discovered that the trigger assembly was sticking. Cleaned it up and it moved just fine. Got it on the lake and could only get 1100 rpm out of it. Replaced the plugs and plug caps, re-timed it, pulled apart the carbs and cleaned them, same result. Tested the CD modules, coils and connections, found no power going to bottom 2 cylinders. Coils and CD modules were good. Finally pulled the flywheel again and found that the plastic terminal block (on top, below the flywheel) was cracked, and the 2 screw connections for #s 3 & 4 were bottomed out and grounding to the engine block below. Fixed that, and got about half power going to bottom 2 cylinders. Looked at the stator and discovered that the first time we'd had it off, we'd caused a couple of little chips in the insulation that covers the coiled copper wires, specifically right where the wires for the 2 bottom cylinders emerge from the stator. My question is: could these tiny breaches in the insulation there cause the stator to arc to the flywheel or engine block and lose partial power to the bottom cylinders? I know that's a lot of info, but I could really use some input here from someone who knows what they're doing (ie. not me).
