mbhoag
Thread starter- Joined
- Aug 29, 2011
- 147
I'm a tad confused on the voltmeter on my boat. Doing some updates and am want to make sure this gauge is giving me good info.
1. Is this gauge normally wired to the rectifier so that it is giving engine voltage, or is it showing voltage at the battery?
2. Assuming it is showing battery voltage, it would only show that of the starting battery, correct?
I am thinking that if it is showing only starting battery voltage, that I need to either add a second gauge to show the house battery, or a toggle switch between the two batteries so the one gauge can do two jobs.
Ideas?
Also, I am assuming that if my Perko switch is set to battery '1'. that the House battery is NOT being charged while the engine is running. If this is the case, is it best to always run with Perko in the 'both' position, or is this asking for trouble on the water?
Thanks All!
Ideas?
Thanks All!
