86 force @full throttle goes nowhere?again
spitz666
i just had my props checked and there fine. i have a brand new prop on there now and it still has the same problem.its fine in trolling speed but when i try to get it to plane out and go the engine races but the boat doesnt go any faster. any other suggestions. thanx for the quik reply
akriverrat
Re: 86 force @full throttle goes nowhere?again
need more info.type of boat?height of transom?long or short shaft?bottom clean?
spitz666
its a 14' 86 bayliner w/ an 86 force 50 hp it's just bin redone washed and polished i belive the transom height is 20". i dont know if its long or short shaft. i boat this boat from a friend and it worked fine last year early then this problem started as far as i know nothing been changed on the boat since then. thought it was a prop prob.but i now think gears or linkage maybe. i dont know a lot about engines im going buy the manual.
rickdb1boat
spitz666 <br /><br />I hate to keep running the prop thing into the ground, but it can only be the prop or cavitation of the prop that's causing your problem. The lower unit is either in gear or out of gear. Nothing to slip inside the gear housing that wouldn't make some bad noises if it were. Scribe a mark on the prop hub and the prop housing and take it out for a run. When you pull it back out, check to see if the marks still line up. If not, the hub is still slipping. It wouldn't be the first time a hub was not installed correctly from the manufactuer. Also, where is your cavitation plate located in relation to the bottom of the hull? (See picture below). This may determine if the prop is "Blowing Out" on take off. Also, do you have power Tilt & Trim? Is the lower unit tucked in toward the boat when you take off? Let us know what you come up with.<br /><br />
spitz666
someone else suggested maybe drive shaft splines are bad?or bevel gear to drivshaft connection?is this a posability if so do i need special tools to disassemble to check the splines geaers in liwer unit or can i fudge it with regular tools? i had a prop shop check my props i have 3 now.,1 new ,the 1 that was on it and the spare they said they were fine. also maybe someone knows where i can have a force serviced in the hudson valley area of new york having a hard time. any help is appreciated . thanx for the replies
