mrnmrskyle
Thread starter- Joined
- Apr 8, 2013
- 56
well, i had a post that got fixed... so new post...
I have had my boat out a few times this year, and found my problem was the timer base was stuck so my timing wasn't advancing.
Today, confident in my vessel, took the father in law out fishing.... and well some really nice guy towed me back in.
the boat started up and ran really easy at the docks... idled nicely through the no wake zone (did notice some surge in idling though) I went WOT and it hit the proper RPMs and got right out of the water (prior issue from the timer base being stuck) well I made it about 1/2 mile and it kept getting lower RPMS till it just quit. I could get it re started run in neutral from idle to higher RPMS. then putting it in gear it would die over an idle RPM most the time and once in a while it'd try to go and once the throttle really started to go it'd bog out and die. The idle in neutral would go from 800-1300 rpms and just varied between each start.
so.... where do I start now? if it matters the engine had a lot of black on it(like a car exhaust will do if it's running too rich) , wether it was from excessive fuel from trying to start
oh yeah, and i'm not sure if the stator is charging... my volt meter never really went up, but i'll check it tonight/tommorrow w/ my DVM.
