86 Johnson 28 SPL
Will Bark
Re: 86 Johnson 28 SPL
If it uses a battery to crank; it should charge the battery with a rectifier. with the engine off use a multimeter to measure battery voltage across the battery terminals, now crank the motor and measure the voltage again; if its charging, the voltage will be higher than before .
