86 Johnson 28 SPL
NEWORLEANS-YAT
Does this little motor charge the crank battery? I can't find any info that states it does.
Thanks
Will Bark
Re: 86 Johnson 28 SPL
If it uses a battery to crank; it should charge the battery with a rectifier. with the engine off use a multimeter to measure battery voltage across the battery terminals, now crank the motor and measure the voltage again; if its charging, the voltage will be higher than before .
