I have a 1986 30 HP Johnson. Unfortunately, I broke the drive shaft for the second time in the first year I've had the boat. First time I hit log and took to mechanic to fix. This time three of the lower unit bolts worked loose and the remaining two sheared. Can't say why. Motor has had a lot of vibration since I've had it, but runs good. <br />I reviewed previous forums for how to disconnect the shift rod to remove the lower unit, but none of the feedback appears to apply to my motor. My manual doesn't mention to disconnect the rod anywhere except at the gearcase, which I did. I then removed the gear case. The water pump and drive shaft are still will the rest of the motor (held on by the shift rod. Any suggestions would be greatly appreciated.
