Re: 86 johnson 60 h motor trim tab
Your best bet will be to buy a service manual for your motor so that you can troubleshoot the Trim & Tilt system... You may also find a copy of a service manual at your local library... Service manuals have all the wiring diagrams you'll need...
<br /><br />If the electric Trim motor is not running, the first things I would check are the solenoids in the small black box (4"x5")on the top of the motor above the carburators in front of the flywheel... You will have to remove the cover on the box to get to the solenoids.... While you press the trim switch, listen for a clicking sound from the solenoids... If they "click" try lightly tapping them and see if the trim works... Also check for dirty connections...
