86 Johnson 60 ignition timing advice please
h_lankford
still slowly putting my winter project back together<br /><br />when I do the max ignition advance test recommended here (Reeves I think, thank you) and I have the spark plugs out to help keep my cranking rpms up, do I keep the plugs connected to the wires and ground them somewhere, or do I just let the wires dangle? I am concerned that the dangle method might somehow damage the electronic ignition (unless all is hooked up. Thanks, Harvey
ob
Re: 86 Johnson 60 ignition timing advice please
You're right Harvey.Ground them.
