86 Mercury 35 HP vibration around 1/2 throttle and up
HeliChopped
The 35 HP Merc on my pontoon starts to vibrate around 1/2 throttle and up. I discovered if I push down or pull up on the engine cowling vibration noise will go away. A rubber strap hooked between the cowling and fence will solve the problem but the higher the RPM the tighter the strap needs to be. Compression Ok. Engine runs great.
The pivot has alot of play on the lower end like the pivot shaft is to long. Not like a bushing is worn but the mount moves up and down about a 1/4 inch when I move the lower end front to back. I dont see a way to tighten the mount. Any body experience this sort of thing? I have ran out of ideas. TIA
carholme
Re: 86 Mercury 35 HP vibration around 1/2 throttle and up
What is the s/n of the engine?
Gerry
HeliChopped
The tag is no longer legible. The tag is blank in the SN area like no SN even existed. Would it be stamped somewhere?
MH Hawker
As a guess its from the prop.
HeliChopped
Serial # A951314.
Replaced prop (new), transom, bolts in engine pod (some loose) and tune-up. Nothing worked so far.
carholme
HeliChopped
Bottom yoke 43 is sloppy loose on shaft 18. I can get a 1/4 gap at the arrow. Maybe it's not the problem but I'm out of ideas.
I thought maybe someone may have come across something like this before.
carholme
That is not an uncommon wear point on Mercury engines. The top and bottom grease seals, item 27 are probably well worn and the lower engine mounts are probably well on their way as well, item 26 under DRIVE SHAFT HOUSING. You can remove cover, ite, 33 and clamp, item 29 to have a look at the lower mounts.
As well corrosion does a good job on the yoke and swivel pin splines.
Gerry
HeliChopped
Are there any remedies for the yoke and swivel pin splines besides 'unavailable' parts replacement?
carholme
Bit early to start worrying about parts availability. You have to take the part numbers and go searching online. As well, depending on how bad the damage is to the splines, if there is any, there is some re-conditioning you can do. Most of the play you are experiencing at the moment is due to the upper and lower grease seals which are probably pretty banged up. It is quite a job to dismantle the engine to the point that the swivel pin comes out but it will be worth it when you are done.
The first thing to do is have a look at the lower mounts and see how much play is there as this contributes to the play from worn grease seals.
Gerry
HeliChopped
The lower mounts have cracks in the rubber but are still in one piece. A search only turned up used ones and since I already have used ones it will have to do.
I will put new seals and do something about that loose yoke. Thanks for your time. I'll post the results when I'm done and tested.
HeliChopped
It's torn down, parts have arrived with NEW lower mounts. If anyone has a cure for the yoke splines I'm all ears.
The wear seems to be more of a rocking issue. The machinist at my work place didn't know since the yoke is cast that's probably where it's worn but it doesn't seem so bad now the motors apart.
The lower mounts may take care of the problem but I would rather address the splines while it's apart if I could. TIA
HeliChopped
Well I got the pontoon out on the water just in time for the end of the season. Replaced the seals and all 4 motor mounts. Everything OK now. Engine runs sweet. Found one of the motor mounts outer aluminum shell was egg shaped. Couldn't see a cause for it, no odd ball wear or anything like that but it's fixed. Thanks for the help gang!
