Re: 86 rude 140 runs rich at idle
hi all,<br />Problem solved. It seems that the linkage to the timer plate was very sloppy,1 bushing missing the other worn badly.probably would allow timer base to be to far retarded.The other fix I did was to clean the check valve in the crankcase drain system,it was blocked.{Seahorse turned me on to this drain system} There is nothing in the OMC manual that would lead you to this check valve,so special thanks to him. Also would like to thank all that helped,Dhadley,hooty,omc guru,joe. sorry if I left any one out.<br />THanks again<br />PS dont know which one fixed prob as I did both before running motor
