Hey Goldie, not sure if I missed this but what are you doing to make it non-skid
Goldie, awesome. And you got it. The seal is just around the prop shaft itself right where you were pointing. Everything else is pretty much bulletproof inside the bearing housing. If you get fishing line on the prop it tends to wrap it around the prop shaft right at that seal, behind the thrust washer that got pulled off.
A thought for you if you are painting any more on the deck, stick a 2x4 across under both dash sections and run a 2x4 up from the ski locker and hold up both at the same time. Easier to carpet too.
Happy Thanksgiving. Those of us working on our boats have a lot to be thankful of - not having to carry around as much weight in our wallets and a wondrous pastime to keep us out of trouble.
Heya Woody, on all my resin layups I almost always go 1%, varying from that is situational. However, with gelcoat the manufactures mixing chart includes this line:
(Colored GELCOATS can require upto DOUBLE the amount of hardener shown. When temperatures are above 85, regular ratios should be used.)
So because of the cold ambeint temperature and the added pigment I doubled the mekp (2%). The following batches I lightened up and ended up settling in at 1.5%. Im more worried about the cold than anything else. The day I rolled the gelcoat the temps where between 45 and 65. Im thinking about some kind of floor blower heater as my propane heater is just too tall.
Yeah, if you're using Black, or Blue, or Red Gelcoat then it's my understanding that additional MEKP is warranted. Also colder temps might require a bit more MEKP as well. You just don't want it to Kick to quick. From what I've been told and learned it seems you want the exothermic process to take it's due course to allow the GC to "Cook and Cure" as it's meant to in a timely fashion which will create the best bond possible. But...as previously stated, you are listening to an Old Dumb Okie so....BEWARE!!!!
The Macho Man says (with gritted teeth and a raspy voice)....
"Brother Go Eat some Turkey, Oh Yeah!!!!"
