carolina_angler
Thread starter- Joined
- Aug 30, 2013
- 11
Hello,
Been researching for days and this by far seems to be the most helpful and informative forum with a huge membership and tons of information.
So here goes!
Boat started leaking at the transom. After inspection noticed a separation of the transom to stringer brace from the transom and a odd looking aluminum plate with sealant possibly the motor mount bolt plate. Stood on the lower unit and not much flex in the transom but I think I now know why the aluminum plate was added to the outside of the transom. Looking to make a partial restoration will know more once the cap is removed. I have a engine stand lined up and will start with removing engine first. Any thoughts on a safe easier fix (assuming there will be no better ways
1st ? - should I remove the control linkage at the motor or pull the full length cables with the motor?
So here goes!
