Re: 86 Yamaha 150 VPro
Basically it is the rpm limiter. It interupts the firing by grounding the ignition momentarily. Disconnecting it only affects its ability to interupt the fire. Since we use the old style ignition such as this on the race motors, we simply take it off and discard it. Disconnecting the white wire to the CDI does disable it, but we are also trying to reduce weight at every opportunity and it is a few more ounces of weight gone when removed. Unfortunately for you, we haven't run into the exact failure you are describing and don't have an easy answer to the cause. Having a pile of these electronics available also makes you lazy. If I did run into it I would have swap out parts available to easier troubleshoot. Quite often the specs for testing electronics leaves something to be desired in the original factory manuals, much less than the Clymer versions. Corrosion in the wiring harness (or other connection problems) has now become one of the main electrical problems that crop up now in these 15-20 year old motors.
