'87 175HP Mariner...Changes spark plugs..quick question.
apaseman
When I changed my spark plugs yesterday, there was a bit of oil on them, not a lot, just a bit. They all had about the same 'cept one, which had a bit more than the others. Again, even this one wasn't covered in oil, just for some reason seemed to have a bi more than the others. Is this a problem?
Just for the record, I am mixing 50:1 directly into the tank as the oil injection system has been disabled by the original owner.
section8
Re: '87 175HP Mariner...Changes spark plugs..quick question.
wish someone smarter would see this. im curious what they will say
ClassyGlassy
Plugs should look wet when burning properly, dry when running too lean, and dripping when running too rich.
There is only 1 way oil gets into the cylinders and that is through the fuel! If the wet plug continues, look at going up 1 heat circuit on the plugs.
apaseman
I wouldn't say they were dripping. Wet yes, but just the one had a bit more than the others, however now that I think about it, that one was a little looser than the others as well, so that might have played into it? I will keep an eye out and pull the new ones in a few weeks to see how wet they look. Unfortunately, I have no basis of comparison as I do not know what too wet is...
ClassyGlassy
dripping and dark is too wet.......
