Evinrude Boater
- Joined
- Jul 6, 2004
- 1,144
I removed the outdrive, split the cases, checked the water pump, spun the shafts by hand, took apart one U-joint and found nothing out of the ordinary. Put it all back together and ran the engine on muffs. There was no noise for 15 minutes of running then it started pinging again for about a minute then went away again. I checked the engine bay while it was pinging and I couldn't hear it there. To me it seems the loudest at the bottom gear case but the prop shaft wasn't turning.
In attempts to see if it's the U-joints I raised the outdrive while it was running in neutral at an idle and turned it from side to side and the pinging didn't return. I'm a little mystified as to why it comes and goes.
Here's the latest video close-up to the outdrive. https://www.dropbox.com/s/mx5g958odl...11541.mp4?dl=0
