87 force 125 carb rebuild?
dalephilbeck
How difficult is it to rebuild and fine tune the carbs on an 87 force 125 and what kit to buy?
bentle
Re: 87 force 125 carb rebuild?
A manual will walk you step by step on the rebuild steps. Not hard to do just to much to list on
Here. Who knows though there prob. Is a wiz out there that has way more exp at this than me.
Good luck.
jerryjerry05
Take it apart first.It might just need cleaning.
At the top of the Force section is a sticky by FrankA called linc and sinc.
Do that.
Is there something wrong that makes you think it's the carb?J
dalephilbeck
Seems like a backpressure problem. Motor will run fine until you submerge it in water. Compression is good, spark is good. I'm going to check th fuel lines and filters also. Tying to do all the simple stuff i can.
jerryjerry05
Possible the idle is set too low.750-800 warm and in gear.
Ethanol is messing with older hoses and squeezies.
Replace all the hoses and squeezie.Check the tank for water.
Remove any inline connectors,they suck air.
Check the tank pick up and the tank vent.
