FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
A manual will walk you step by step on the rebuild steps. Not hard to do just to much to list on
Here. Who knows though there prob. Is a wiz out there that has way more exp at this than me.
Good luck.
Take it apart first.It might just need cleaning.
At the top of the Force section is a sticky by FrankA called linc and sinc.
Do that.
Is there something wrong that makes you think it's the carb?J
Seems like a backpressure problem. Motor will run fine until you submerge it in water. Compression is good, spark is good. I'm going to check th fuel lines and filters also. Tying to do all the simple stuff i can.
Possible the idle is set too low.750-800 warm and in gear.
Ethanol is messing with older hoses and squeezies.
Replace all the hoses and squeezie.Check the tank for water.
Remove any inline connectors,they suck air.
Check the tank pick up and the tank vent.
