87' force 125 prop question
rammerjammer05
1987 Force 125hp Model#1258v7b. Looking at buying a new 3 or 4 blade aluminum prop. Will the Mercury props work with my motor. If so I saw some here on IBOATS for a
125hp 1977 and newer Mercury. The 3 blade TURNING POINT HUSTLER #H1-1319, Hub #30. And the MICHIGAN WHEEL VORTEX#992114 Hub#XHS102. And the 4 blades were
SOLAR AMITA #1413-125-19 and the VOLVO PENTA #41102324 HUB# 41102351. Thanks for the help all.
jerryjerry05
Re: 87' force 125 prop question
There is a prop section.Post there as they are real good at answering your questions.
The Force 125 is a good motor but repropping to a 4 blade probably won't make much difference.
Figure out the RPM's at WOT and post the size prop you have now.
Going to a stainless will help a bit but maybe look into a bigger motor.Good luck.
