Re: '87 Force 125 tilt and/or trim?
If I understand you:
Tilt /trim unit will raise and lower engine with engine shut off, in neutral or gear, and when engine is running, but only in neutal. Motor, pumps, and cylinders all working properly. This before you jumped it directly to the battery.
Also, once tilt/ trim unit has raised the engine, it is rock solid, even against a heavy load. All valves working ok.
Once the engine is placed in forward gear in any condition mentioned above, the tilt/trim unit rapidly lowers the engine all the way down.
Your tilt/trim motor has at least 3 wires connecting it to the wiring harness.
I can think of two things.
A Flow control valve is unseated allowing fluid to vacate the lifting cylinder. Coud be a check valve or a spool valve that is retracting to open position. I think these valves operate, by pilot pressure, and according to pumping direction. It may be that in gear your pump is switched to pump backwards with the fluid circlating in reverse. That would retract your engine in a hurry.
Second, I suspect some sort of ill working electrical interlock is at play. To be sure I would run continuity checks on wiring between the shift linkage mirco switches and pump to check for polarity changes in each shift position.
I think this problem has been with this boat for a long while. Dealers prepping new boats for sale have caused untold problems. I hope you solve it.
I solved it for now but it's snowing outside right now, it may just wait till spring now.
My impression is that there is an intentional interlock system, but that should have been eliminated when I direct wired a switch to the pump and battery. I cut the wire going to the rear of the trim ram, and the sensor wires are still on the pump and the tilt ram. And it seems to work fine, but I have no idea why, whether that wire has something to do with it or if the colder temps are the cause. I ran it in gear at full tilt on the ears the other night for about 20 minutes and it stayed up. With the pump wired direct the tilt and trim will work at all times, even allowing movement in reverse and neutral. If I leave it this way I'd have to be careful not to over trim or tilt the motor, you could easily 'trim' the motor right out of the water if you stayed on the switch. I think that's what the interlock was meant to prevent, or the fact that you can now tilt a spinning prop out of the water. That wasn't possible before. Before, if you started the motor fully tilted or trimmed, it would drop all the way down, (this wasn't possible due to a neutral safety switch though), but now it would stay put regardless of shifter location.
Maybe the sensor switches have something to do with it as well. I do notice that the trim gauge has about 7 wires going to it and with that red wire cut, it no longer works at all, no lights, nothing. I don't really care about the gauge or the buzzer, I can tell when its trimmed right without a gauge.
I've never had a boat before with a working trim gauge, why start now.
If I get a warmer day I'll wire the new switch in permanent to the dash with a couple of fuses in line too. The other wires are no longer needed as far as I see. I also think I'll rewire that micro switch to a new relay and use it only as a neutral safety switch, with no connection to the tilt and trim. I'd still like to know what or how that red wire causes the pressure to dump, unless they did put a solenoid in the trim ram. For now, so long as I can find a set of coils for this thing, I'll leave it where it is, if not, I still have it's replacement ready sitting in the garage.
