grininmonkey
Thread starter- Joined
- Aug 26, 2008
- 35
I just picked up a Bayliner with the 125 on it, made first trip to lake and have some issues. Before taking to lake I checked it out running in the yard with muffs and tried cleaning the carbs and setting the throttle cam link to a point where it would just stay running in neutral as it was cutting off.
During the lake trip, (at first) it was staying cranked at the landing in neutral/just in gear maneuvering away from the landing and a no wake zone.... as soon as I got up to speed, passing the 3000RPM range a very loud noise was happening... below that range it purred and was quite. At WOT, it would maintain for a good few minutes, and then have sudden RPM dips and jumps by 300+/- range and act as it was going to cut off. I stopped and go many times and this behavior was consistent.
It never shut off when throttle was being applied, but after having ran the motor for some time, the idle was way low and would not stay cranked over 30 seconds.. I would restart and if I did not apply throttle in some way.. it would putter and and RPMs just slowly drop and shut off.
At the lake I did the carb idle needle adjustment routine per the manual twice.. to the best of my hearing and the behavior was not improved. I can tell the lower carb responds well to needle adjustment, but the top seems to respond very little. I am worried the seat may be damaged?
Looking over some pages from the shop manuals I came across something that did not make sense. It appears that the throttle cam is suppose to have the arrow (notch markings) centered on the carb throttle roller. The picture shows where it is currently setting.. which is in neutral and the only place it will stay cranked right now. If I do as they say and center the arrow to the roller.. the throttle came will not even touch the roller.
Is there something wrong with the throttle stop, link and throttle cam positions?
How do test/see for certain if the top carb needle seat is bad? (when I took the carb off to clean I could not see in the hole very well)
Could the very loud noise in the mid range RPM be bad fuel mixture due to in correct carb settings or something else?
