87 Force 85 HP choke sticks/stuck
kevinpy
My choke is sticking. Sometimes after manual choke it works for a while. Can is be cleaned or does it require replacement??
Thanks,
Kevin
jerryjerry05
Re: 87 Force 85 HP choke sticks/stuck
Sounds like it's dirty.WD-40 the plunger.Then cycle it a few times.Then WD it again.J
john from md
I suggest that you clean the choke solinoid with carb cleaner and then lube with a spray oil.
John
Frank Acampora
Check the three gaskets that separate the airbox from the carbs. They swell and sometimes bind on the choke stop levers. A simple trim job with a razor knife will help, otherwise take a pliers and gently bend a little clearance in the stop lever.
