Unbalanced
Thread starter- Joined
- May 11, 2009
- 89
I'm getting close to getting this old engine running like new again, but I have a question in regards to the idle speed screw and the throttle cam.
If I line up the cam to the line on the curved arm, I can't get full throttle. The manual says to adjust the length of the arm to get the butterflies horizontal at full throttle, but then I have to adjust my idle screw all the way in to get 750 rpm at idle in gear - on the water. So now at idle the line on the cam is 3/4" lower than the cam.
I seem to need to bump the idle a touch more. When shifting from forward to reverse, sometimes it quits. Starts right up and idles, but the transition causes it to quit.
Oh, and another question: I installed a new fuel pump kit and after 3 hours of running, it tore. Did I squeeze the bulb too hard or did the SeaFoam attack it? Good thing I ordered two!
FWIW
My compression is 130psi on 1/2 and 128psi on 3
Full throttle runs 5K on a 13.25x17 stainless at 35mph.
Timing is set to 30deg (the middle mark) at full throttle.
De-carb (SeaFoam) has been done 2 tanks ago.
I've cleaned the carbs and installed carb kits. Floats are level when inverted.
I replaced the stator and starter.
Puddle drain reeds and manifold cleaned.
New fuel lines and clamps installed.
New fuel pump diaphram and gaskets.
New Boyesen reeds and gaskets.
Plugs are new Champions.
Battery is new and fully charged. Meter reads 15 volts when charging.
Telltail added.
Thanks,
Jeff
FWIW
Telltail added.
Thanks,
Jeff
