FingerLaker
- Joined
- Oct 31, 2018
- 37
Hi all, newbie here... 87' Bayliner 1700 Cobra.
My 87' Force 85, which ran like a top at all RPMs- once I got her into gear with a bit of a throttle shove and some luck (3 tries..) will stall every time from a smooth idle, warmed up or not. Even after a cruise of nearly an hour, with nearly perfect transitions through RPM ranges, including a fairly low one, still stalled when back at the ramp shifting into reverse. She did start a little hesitantly every time, but I think I have that trick down. Typical Choke a bit- then no choke- till quick repeat fires (about 3) result in her catching at idle.
Sorry, I need to get a tach as the boat doesn't have one, but again the idle seemed perfectly stable. Not once did she stall once at idle. This was her first outing this year after sitting for about a year in winterization state. I know, terrible, but I bought her in Nov last).
Any ideas? Do I just need to idle her up some? Or do shifters sometimes cause this problem?
Thanks for any advice any may have, happy boating!!
-Finger Laker
-Finger Laker
