87 johnson 90 tach j90tlcur
ctrock29
hi guys I’m not getting continuity from the grey wire on motor terminal strip to signal wire at tach. My question is can I run a new wire from motor direct to tach?
jakedaawg
Did you isolate the wire (unhook each end) before testing? If so and the wire is broke yes, you cane run a new wire. I suggest a bullet connector near the harness connector in case you need to pop the motor off for some reason.
