Ok. So i fixed the previous problem. Now i have a VRO issue.
I primed the VRO bulb on my 1987 johnson 150GT. The bulb was firm. As i squezed the out flow side of the primer bulb came out and oil leaked out. I reconnected it and put on new clamp.
New issue after i did that and wanted to test my engine from a previous issue.
I started the motor and as is was running great. about a minute into it running my buzzer started sounding at the control box. BUZZING ON AND OFF. I shut down motor and bulb was not soft or rock hard firm. I primed and restarted same buzzer sound.
What could it be. Would it be no oil.flow and could i have an air lock some were from when the buld came apart or is my pump messed or does a buzzer on amd off mean something else. My oil tank is 1/2 full.
