archbuilder
Thread starter- Joined
- Sep 12, 2009
- 5,697
I just put my rebuilt boat in for the first time last week. I have a 87 inline 115 Mercury on her. I wanted to get her in, so a few things were a bit "unfinished" including the battery hold down. I put a couple of I screws into the transom (secast) and bungy corded the battery to it. That put the battery slight out of level, maybe 5 to 10 degrees. I charged the battery the night before, (new battery) at 2 amps. It wasn't quite to 100% when we went out but close. When I first put her in, the motor was putting out 13 volts. Later I noticed it was running at 16. I thought it might be a connection issue with the gauges....still have some issues to work out on the mount / terminal connections. Anyhow I made a note to check that out. This morning I was getting everything ready to install the carpet and pulled the battery out. Battery acid had ran out the back of it from the cells. I did some research and from what I'm reading the battery acts as the voltage regulator on these charging systems, is that correct? Sounds like you only have the stator, rectifier and battery? I'm wanting to hit the lake next weekend, so I'm excited about figuring this one out. Here is my list of possible issues:
Regardless if high voltage is an issue, perhaps I should by one of the aftermarket controllers that regulates the voltage? I'd hate to smoke an I-pod with high voltage! Has anyone had any experience with those? I'm still trying to figure out if it replaces the rectifier or supplement's it.
- Bad battery, short or weak cell
- rectifier out?
- charger just boiled over the battery? Its an automatic so that doesn't seem likely.
- The angle of the battery caused the acid to run out? It was still on the battery, so maybe that is the issue?
