87 OR 89 OCTANE 2001 MERC 115(FUEL CLEANER?
NITRO750
HAVE NEW 2001 MERC 115 WENT THROUGH BREAK IN PERIOD (EXTRA OIL) CHANGED PLUGS ADDED 89 OCTANE,NOW BOATS SLOW TO PLANE REAL BAD WITH LOAD.<br />COULD THIS BE GAS?? I RECALL MECH. TELLING ME 87??<br />CAN I ADD A FUEL CLEANER?? OR DO I HAVE OTHER PROBLEMS? THANKS
fireman 757
Re: 87 OR 89 OCTANE 2001 MERC 115(FUEL CLEANER?
run 87 that's what they were made to run on. Have you changed your plugs after your break in period? I would as you have burned extra oil. Go to your regular mixture.
wilde1j
What boat are you running? It may be the motor is marginal for the boat. Did boat plane w/ same load quicker before? Or is load much more now?<br /><br />Octane doesn't make any difference in power, just deposits (more w/ 89). You should only use 87 octane as fireman 757 suggested.
NITRO750
THANKS GUYS<br />I RUN A NITRO 750 17'6 WITH A 115 TRACKER (MERC).<br />OUT OF THE BOX IT WAS CLOSE TO 60MPH. NOW MID 50, REAL BOGGED DOWN AT START, CHANGED PLUGS ONLY THING I CAN THINK OF WOULD BE GAS? LAST COUPLE TIMES I'VE USED 89 OOPS!!?? SHOULD I ADD A FUEL CLEANER? OR JUST FILL UP WITH 87! THANKS
Spidybot
Nitro750<br /><br />We can't get anything lower than 92 octane here and that really never has been a problem.<br /><br />Your issue is not the fuel quality. Must be something else i.e. some adjustment not perfectly in order.<br /><br />As it is new there must be a warranty etc. so talk to your dealer before doing too much experiments. Not that I think you'll harm it, but it is important not to give the dealer any excuse for backing out.<br /><br />What rpm do you reach at WOT?<br /><br />And finally a kind hint: Do not use capitals unless you wanna SHOUT at somebody.
