87 Sea Ray face lift
PaJon
With the beautiful weather here in central Pa, I took the cover off my Ray to do some maintenance. After looking at the old girl, I thought it was time to give her a face lift and make her beautiful again.
My plan is to replace all the interior, replacing the brown carpet with gray, redoing all the vinyl and repainting the brown gel coat with red, and replacing the carpeted ski locker cover with a teak one.
Here is the ski locker now
This is the one I am going to install
The first panel is done. Before
and after
New vinyl and wood backing for the glove box
PaJon
Re: 87 Sea Ray face lift
My plan for today is to get the dash panels done and start the bow seats. I am surprised how water logged the wood backings are, I'm going to need more ply than I thought.
Alwhite00
Looking good, Keep the pics comming.
LK
palace
Hi Pajon, Where did you get your carpet? 20 oz.?
Bob_VT
Remember to seal up your new plywood ;)
Looking very good.
Bumperlt12
Gotta love the 80's brown. That half the reason we upgraded from our last boat.. brown scheme..
PaJon
A local carpet store had it. It's 12 or 14oz, not as nice as the original but only cost me $20 :D
PaJon
Looking very good.
I'm sealing it. The old wet wood from the glove box was 4 lbs, new new wood after being sealed was just over 1 lbs.
SDSeville
Looking great. Your boat is similar to mine, but a year newer. Keep it up and keep the pics coming!
scottn83
looking good I like that red strip you have in the pad you finished. I am on the same path with my cheetah. I have rearranged my seating and added a sundeck. I am down to the rear side padding and just about done with the sundeck.
PaJon
I didn't have much time to work in the Ray this week yet, but here's what I have done.
Old bow seat
New seat cushion. I'm glad my mom is retired and likes to sew, lol
Old bow side, very wet foam. Had to replace most of the foam too.
New side
And got the new carpet cut for the bow.
PaJon
Are the pictures to large ? Should I post them another way ?
PaJon
Thanks. I wanted to break up the white vinyl. I'm adding red to the seat cushions too.
tpenfield
Looking good !!! :cool:
What . . . no more of that 1980's brown ??? :D
PaJon
I have lots of teak wood around from years of playing with boats. I'm using as much as I can in this project. I replaced the stainless hand hold with a teak one.
new one with the teak
Test fitting the carpet
Installed
It's starting to take shape
jigngrub
I think you should lift the decking and lets have a look at the bowels of that boat!;)
PaJon
Do you see something I might have missed ?
Some of the deck will be pulled to put in the ski locker cover. I pulled the tank cover and removed the tank to get core samples of the stringers before I started. I also drilled the motor mounts and transom.
Alwhite00
Boat is looking great, You will be proud when done. Do you want to get rid of that stainless hand hold? PM me if you do.
Thx.
LK
PaJon
I haven't had much time to work on it but the bow is done. I'm not putting the floor carpet in until I'm done with the fiberglass work for the teak ski locker cover.
I ran out of staples and had to run to Lowes. Can anyone tell me the difference between these ? Other than the $4.00 price difference. The bar codes and item numbers match 100%. I guess marine grade is more, lol
