jay dezman
Thread starter- Joined
- Sep 19, 2004
- 85
i have a pair of these and one is/has lost some performance.<br /><br />the torque on acceleration is way down (one engine will plane the boat and the "weak" one won't) and max rpm on the weak one is 800-900 lower.<br /><br />i have good compression (110+ in all cylinders with a range of +/- 5)<br /><br />all 6 plugs are firing.<br /><br />i've tried to adjust the throttle position sensor and find the procedure in the manual a little confusing (after a hard week at work i must be brain dead). at any rate, there is a pin that is used to align the gear with the internal pot and there is also mention of a particular voltage reading at idle. what i have done is put the pin in place to get everything installed, then pulled the pin and rotated the switch housing to try to get the voltage reading. <br /><br />is this the correct way or have I screwed it up.<br /><br />by the way the nearest suzuki dealer i know of is about 150-200 miles away so i have to figure this one out!<br /><br />thanks all for your help.
