'87 Suzuki DT55 erratic idle
Al Mottola
Hello:<br /><br />This motor has had one problem after another, each time I fix a problem, I find another. Now the idle speed is completely erratic. Spark is good, gas is new, carbs are clean, compression is OK. Is there any chance that there is a leak in between the cylinders? This in theory could cause this problem if a cylinder is drawing fuel from another. <br /><br />Also, this engine does not like to run under load. Runs above idle OK until you out it into gear. I do not know if the two problems are connected.
Al Mottola
Re: '87 Suzuki DT55 erratic idle
One more problem found. The idle switch which feeds a signal into the electronic control module does not have any affect. Are all these problems pointing to a bad electronic ignition module?
