87 toyota camry, steering wheel pulls
ezbtr
and it's already had an alignment, tire wear is perfect, wheel pulls to right when you let go of it, steering box? Havent checked air in tires but they look fine.
642mx
Re: 87 toyota camry, steering wheel pulls
Start with the air pressure, then take it back to the shop that aligned it and ask them to adjust it for road crown.
WizeOne
Make sure the front tires are evenly inflated then swap them. I've seen tires, with no visual clue, that caused the problem. They should have evenly inflated the tires when they did the alignment, but you never know. I've seen some pretty schlock alignment jobs as well.
I really doubt that it has anything to do with the steering box. Loose, worn rack and pinions cause slop in the steering, not pulling.
ezbtr
yup was a tire, he took it to shop and they rotated for free :) no more pulling, gonna pick it up in a few hours :>) $900.00
