87 yamaha 150 pro-v RUN FOR ONLY 1 MINUNIT THEN STOPS
mcgill
:(I Have a 1987 yamaha 150hp:mad: pro-v I Never Had It In The Water THIS WILL BE THE FIRST . 2 Things Are Going On I Can Not Get Gas Out Of The Tanks the motor sucks the bolb flat,,,, motor stills I Changed The Fule Filter,, Now I Am Useing A Gallon Container With Gas and dry gas in it.To start the Motor but Runs For only 1 Minunit Then Stalls,,,,, I Pull The Chock open and started It still Will Start Then Run Then Stop, Also to day 5/30/09 I moved the two fule pumps open them to check the diraham look to be in good shap.also Why Is There Two Fule Pumps, On This Motoris one just for ide? need some information from some of the loung time boat owners
