beckoning
- Joined
- Dec 15, 2010
- 182
'88 100hp, 4 cyl oil injection. For no apparent reason today, while cruising at 3,500 rpm, the engine raced as if it came out of gear. I checked the prop for damage (cavitation?) and it was clean, even though it is an old prop. Nothing has changed on the boat to cause interference to the water flow under the boat to the prop. I haven't removed the prop yet. Could it be the rubber spline gear on the prop has worn so the spline gear and shaft engage at slow speed, but over 2,000 rpm the propeller shaft just spins inside the prop? It seems to be rapidly getting worse as if the rubber spline gear is quickly wearing off.
If the spline gear is the problem, can I replace the rubber spline gear on the prop? Or is the best approach to replace the prop and spline?
