First Id like to say this is an amazing forum! Its already helped me a dozen times in getting my outboard running better. (not perfect).
So the engine is a 1988 Johnson 150VRO. The previous owner has already removed the oil injection for me.
Now my current problem is:
Engine idle - misses even 20-30 seconds. example *idle idle idle idle idle *cough* idle idle I know that like 10 year old lingo but it works right lol.
When engine is at idle the ball will soften. I replaced the ball ever year.
Engine Run - 3/4 throttle or more and it will suck the ball completly flat and die out on me.
When priming the ball i can visually see fuel coming out of carbs, now i did notice i probly need a new bowl gasket on the middle carb. But Im guessing that problem is more of less a stuck needle.
What Ive done:
Cleaned and inspected carbs to include checking needle for obstructions and floats.
Ohm'd out my primer/choke 8ohms. Which i believe is ok.
This year I have not checked my filter/seperator becuase i dumped it about 4 times last year while working on this problem.
I sealed the carb cover to ensure no air leaks.
Im ruling out the fuel pump since it will suck the ball flat as a pancake.
I have in inboard tank and have replaced ALL fuel lines from tank to each carb.
I have checked my vent line and it is fine.
--- So would a stuck needle in the carb cause the engine to run like it is and draw the ball flat? I understand the flooding is probly due to that but cant figure out the cough and the ball problem.
Thanks in advance fellas.
Frank Wood
Pennsville NJ
What Ive done:
Frank Wood
Pennsville NJ
