I have the seloc 1404 manual, where I got the photo of how it's supposed to look when correct. I would love to have one, but don't. The written directions in the seloc is rediculous.
1. Motor off.
2. Push spark adv arm to it's Stop.
3.DO NOT actuate throttle lever.
4. Adj screw until contact with P/U arm occurs.
5. Done.
This procedure is great for pinpointing the exact TIME when the screw begins to advance the throttle past half-to-full. But my problem seems to be a mis-alignment somewhere, like the carb needs loosened and jacked to the right, or maybe the brace that the throttle cam pivots on is bent. Both the pickup arm and the throttle cam/screw that engages it are pivotted on immovable (presumably) structures. It would seem I need to shorten the distance between those two pivot points so the screw changes it's angle of attack.
