itspaidfor
- Joined
- Apr 26, 2005
- 18
I have a strong steady tell tale stream about the first 5 minutes of running on the water then the stream goes to spitting a water and steam mixture back and forth if i slow down to idle it cools down almost to normalthis. motor has no thermostats .the impeller and cup section of the pump have been changedcompression. is in spectimming. is about 3degress after tdcplugs. look great no water in cylinderseven. removed telltale fitting in the head to peep inside ,looks cleanthe. dang water pressure never drops below 3 psi at near idle even when steam is comeing out .any suggestions ,thanks
